Hi
Im a Serato DJ user and was wondering why I cannot use the FXsound when my device is connected.
Any help or workaround is greatly appreciated!!
Thanks
Hi
Thanks
First line of defense:
Have you already tried to fully uninstall FxSound with specialized complete uninstaller software like IObit Uninstaller Free or BCUninstaller, and then reinstalling?
Hi
This was a first install to see if it was possible… I think it has to do with Serato’s ASIO… FXsound works fine without the hardware connected…
Well, just try uninstalling and reinstalling with specialized software.
Then report back here with your results.
“This was a first install to see if it was possible… I think it has to do with Serato’s ASIO… FXsound works fine without the hardware connected…”
I had a similar experience with Wasapi, which is like ASIO, it was discussed here -
These programs need to have the output set exclusively to them, thereby bypassing FX.
