Just recently I find that if FX has been inactive for a while (no audio being played) it has automatically shut itself down. Is this a new feature? If so – it’s annoying.
Can you please share the log file %APPDATA%\FxSound\fxsound.log. It will help us find out if the application has crashed.
Where would I find such a file. What is the path?
The path is %APPDATA%\FxSound
File name is fxsound.log
%APPDATA% is the environment variable and the path varies based on the username on the PC.
Starting at C\ , how do I get to %APPDATA\FxSound ?
Is this (attached) the correct file
(Attachment fxsound.log is missing)
I am getting my file bounced back with the following message, and now it seems my eial address has been blacklisted by your mail server:
Do you want me to try uploading the file. Nothing in the diretory younspecified was called fxsound.log just "
fxsound"
**Unfortunately some attachments in your email message to [“incoming+3a2aaa83afec59da07ae5c5be8db5104@fxsound.discoursemail.com”] (titled Re: FxSound: FX keeps shuttig down if inactive) were rejected.
Details:
fxsound.log: Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, heic, heif, webp, txt).**
If you believe this is an error, contact a staff member.
The Text Document in explorer is fxsound.log. The extension is hidden in explorer.
Since the file could not be attached, you can open the log file in notepad and share the exception log. If you find any information in the log which says “Unhandled exception”, copy the complete details following that and paste it in your reply.
I cannot send anything by e-mail (this answer is on the web messaging platform.
I will first tried uploading the file here and got an error message from your platform – the same error message from your mail server.
I’ve copied the file to my desktop. Should I manually rename copied file from fx sound to fxsound.txt.
I tried copying the contents of the file into the messaging platform and it said “too many characters”
I tried emailing a cut and paste and it seems that after I previously e-mailed the log file with an “illegal” name I’ve been blacklisted on your e-mail server
You will not be able to email it to the forum.
You can copy paste the error content in the log file to the forum discussion.
Otherwise you can upload the log file to a cloud drive like google drive or dropbox and share the link.
Do you not have any control over your e-mail server. Is it not possible to whitelist my e-mail address
When I try to copy the file into the online message platfrom I get an error message that my message “has too many characters”
I have already told you all of this.
This is the latest error message from your online messaging platform.
Can you please escalate this issue to someone capable and trained to offer suggestions that actually work? Everything you have suggested has resulted in error messages!
copyoffxsound.txt (129.7 KB)
The system just upgraded my “trust level”
Thanks for sharing the log file. It gives some idea on the possible causes of application crash and closing.
If possible can you also share the fxsound.dmp file in the same directory. You won’t be able to upload it in the forum. So, please upload it to this dropbox link Dropbox
