Does fxsound drain my headphones faster?
no big deal, i just want to ask if using fxsound will make my bluetooth headset run out of battery faster than usual? (because i find the sound of the headset when using fxsound is much louder)
Playing audio at a higher volume will indeed use up more of your headphone’s battery, but the FxSound audio processing pipeline runs on your computer’s resources.
Have you checked your product’s specs for the technical data on its battery?
https://cleeraudio.com/battery-draining-issue-in-bluetooth-headphones-try-these-smart-hacks/
