Hi guys. More than 10 years so far i’m happy to enjoy with DFX (12.023).
Today i have a question:
Is that possible to make both audio devices be active under DFX preset in same time?
For instance, i’m too lazy to switch between Speakers and Headphones each time i need it, but i don’t know how to make them play at once. Any ideas?
Hi Dmitriy,
As far as I know, there is no way to do this in FxSound.
There are two things you could try though, that I can think of at the top of my head:
Installing Voicemeeter (Banana) and using multiple inputs;
Enabling Stereo Mix in Windows.
Here to help,
dool
There is no single solution, there are many and all are hardware dependent. This is why tech support forums do not list solutions. Your specific hardware is not described and no solution is offered here.
The linked article’s tech level is consistent with the advice offered above. See:
