Any way to replicate the Deep Bass slider from Eqfy “android”? Probably the best bass enhancement i ever heard.
If you choose 30 Bands and Max Q=3 in Settings.
Q = fc/Δf = 3 = 20 Hz center / ~7 Hz (-3dB BW)
The graphic sliders are now fixed instead of default low Q=1 parametric f.
Now you have 3 sliders per octave starting from ;
20 25 32 (40 = octave 2x20)
Now you can choose your fave EQ and tweak sub-woofer bands with more precision. Use the Bass Boost if necessary, but also compare with everything Flat (Default) .
