Using updated Win. 10 (32bit) and Fx app. Fx set as default. Device has 1.33gHz Intel Atom processor. Have looked at other posts; any “background” settings with numbers and hardware acceleration seems unavailable. Is a re-install worth the effort or is this usage level normal.
FxSound application uses OpenGL. If your graphics processor supports OpenGL and if it not enabled, can you please enable it and try.
Hi @dech. Welcome back.
Have you read through the standard troubleshooting list (bannered and pinned at the top of the forum)?
Points 1 (updating to the latest version if you haven’t done so yet), 8 (running as Admin), and 16 through 20, seem most relevant to your issue.
