BSOD related to fxvad.sys
Blue screens appear at random moments, experimentally using “verifier” it was found that the error occurs because of fxvad.sys. When deleting the driver + software - the computer starts with “verifier” without problems, it is worth installing the driver - an instant blue screen. I tried to install different versions - did not help, certificates - did not help. Complete removal of the driver and manual installation did not help, with the driver from Windows 7 - the program does not work.
Output.txt
Audio Playback Devices
e[38;5;51m1. Speakers (fifine Headset) [Speakers]
e[38;5;10m[Active]e[38;5;45m [2 - Channels]e[38;5;27m [32 bit, 48000 Hz]e[38;5;196m [Volume: 6%]e[0m
e[38;5;51m2. FxSound Speakers (FxSound Audio Enhancer) [Speakers]
e[38;5;245m3. Speakers (Realtek(R) Audio) [Speakers]
e[38;5;88m[Unplugged]e[0m
e[38;5;245m4. Realtek HD Audio 2nd output (Realtek(R) Audio) [Headphones]
e[38;5;245m5. SteelSeries Sonar - Gaming (SteelSeries Sonar Virtual Audio Device) [Headphones]
e[38;5;88m[Disabled]e[0m
e[38;5;245m6. SteelSeries Sonar - Media (SteelSeries Sonar Virtual Audio Device) [Headphones]
e[38;5;245m7. Speakers (fifine Microphone) [Speakers]
e[38;5;245m8. SteelSeries Sonar - Chat (SteelSeries Sonar Virtual Audio Device) [Headset]
e[38;5;245m9. Mi Monitor (High Definition Audio Device) [DisplayAudio]
e[38;5;245m10. SteelSeries Sonar - Stream (SteelSeries Sonar Virtual Audio Device) [LineLevel]
e[38;5;245m11. SteelSeries Sonar - Aux (SteelSeries Sonar Virtual Audio Device) [Headphones]
e[38;5;245m12. SteelSeries Sonar - Microphone (SteelSeries Sonar Virtual Audio Device) [LineLevel]
e[38;5;245m13. Digital Audio (HDMI) (High Definition Audio Device) [DisplayAudio]
e[38;5;88m[Not Present]e[0m
e[38;5;245m14. NVIDIA Output (NVIDIA High Definition Audio) [DisplayAudio]
e[38;5;245m15. Headphones (High Definition Audio Device) [Headphones]
e[38;5;245m16. Mi Monitor (NVIDIA High Definition Audio) [DisplayAudio]
e[38;5;245m17. Digital Audio (HDMI) (High Definition Audio Device) [DisplayAudio]
e[38;5;245m18. Digital Audio (HDMI) (High Definition Audio Device) [DisplayAudio]
e[38;5;245m19. Digital Audio (HDMI) (High Definition Audio Device) [DisplayAudio]
e[38;5;245m20. Digital Audio (HDMI) (High Definition Audio Device) [DisplayAudio]
e[38;5;245m21. NVIDIA Output (NVIDIA High Definition Audio) [DisplayAudio]
e[38;5;245m22. NVIDIA Output (NVIDIA High Definition Audio) [DisplayAudio]
e[38;5;245m23. Speakers (Wireless Controller) [Speakers]
e[38;5;245m24. NVIDIA Output (NVIDIA High Definition Audio) [DisplayAudio]
e[38;5;245m25. Speakers (High Definition Audio Device) [Speakers]
Audio Sessions
e[38;5;245m1. Discord.exe
e[38;5;172m[Inactive] e[38;5;10m[Volume: 100%]e[0m
e[38;5;51m2. FxSound.exe
e[38;5;10m[Active] e[38;5;10m[Volume: 100%]e[0m
e[38;5;245m3. Spotify
e[38;5;245m4. System sounds
e[38;5;245m5. Telegram.exe
e[38;5;51m6. wallpaper32.exe
BlueScreenView
Are you using the latest version of the application and driver on Windows 7?
I tried everything, I have Windows 11. Different versions of the program with different versions of drivers, including from Windows 7
Problem is actual
Thanks for reporting this. We will test the driver with verifier enabled and make it robust in coming releases.
Any news?
Any news?
I enabled verifier with standard settings for fxvad.sys. But, I haven’t encountered a blue screen yet. I will continue to test and look into the issue if it crashes.
If it crashes with any specific test enabled, please share the details.
