Every other app works fine with FXSound but when I switch to it in Roblox it just wont give any sound at all. This is a sudden issue because it was working fine yesterday.
Good evening, and welcome to the forum.
Which versions of FxSound and Windows are you running?
Does this happen with every browser and every sound device?
Also, have you read the main troubleshooting list yet (bannered to the top of the forum)?
Software says it is up to date. roblox has their own sound settings, i can change which audio device i use in-game. I did read the bannered forum. Thanks
I have finally found the solution. I am so sorry for the trouble.
No problem.
What was the solution? I have the same problem
@GylyMonster could you share the solution that you found?
It seemed i had muted the app using the sound managing tool usually at the bottom left or middle left of your screen when pressing Windows + G. I just completely forgot about it.
