Volume Mixer
Can I still change my volume on different applications in FxSound? I noticed that FxSound compiles all audio into one and I cannot change the volume for my music and browser app audio for example. Is there a way can i change this?
If FxSound Speakers is the audio output,
you can change the system wide volume from Settings->Sound->Master Volume
or change the volume by clicking the speaker icon in system tray.
At the same time volume can also be adjusted in individual application, and the change will be specific to that application.
For some reason i cant change it, theres nothing happening as i change the volume slider of a certain application. Yes the Fxsound is my sound output but i still cant change it
just found a workaround to the problem. thanks for the help
