Hey all so I installed the steelseries sonar for when I am playing games but not completely sure I set it up correctly, since fxsound has to be the default output on windows when its running so wondering if this is set up right? I set Fxsound to the sonar gaming and then set the sonar to my headset. Is this correct to make it work? Since my games run on the default output running it like this would make the sound go through fxsound, then through sonar, and finally to my headset correct?
So, you have set FxSound Speakers as the default output device on Windows and in FxSound selected SteelSeries Sonar which is a virtual audio device as the output. SteelSeries Sonar is connected to your physical audio output device.
We have not tested a similar setup, but in theory this should work and should be able to hear audio on your headset.
