Is there a way to configure system tray icon to show preset name on hover?
I love using this app for different things and have presets that I switch between often. Is there a way to display the preset in the system tray icon on hover?
Also, I’d like to request a way to quickly change presets - either by utilizing a pop-up menu on notification tray or system tray (or both), allowing the user to select a present. Or perhaps user-defined shortcuts for presets. Better: shortcut that opens preset list (with first 10 presets numbered) so that using shortcut to open list, typing 1-0 opens respective preset 1-10.
Apologies if something like this is available and I haven’t figure it out yet.
Thanks for these suggestions to improve the user experience of the application. We will look into the feasibility of implementing these.
