Hi need help with a EQ Setting PUBG
Hi I would also like to help me with some EQ Settings for PUBG Steam, thank you. I use Corsair HS80 USB headphones but with iCUE software I can’t hear any footsteps at all, just the drag and the bombs and the ambient sound.
Hi Alex,
Just to be clear: are you looking for help finding the appropriate settings in FxSound to better hear the footsteps in PUBG: Battlegrounds?
If so, I guess the best thing to do would be to use some combination of the Dynamic Boost slider (which increases overall volume) along with the Clarity slider and the two or three Equalizer sliders most to the right (i.e., the high frequencies).
To elaborate a bit further; you’ll probably achieve the best high-frequency boost by turning the dials under the Equalizer sliders all the way up to their highest levels - that’s 6.35 kHz, 11.76 kHz and 16.00 kHz for the three sliders most to the right, respectively.
There are also twelve additional Bonus Presets you can download for free at
it hasn’t been very helpful what you have told me some screenshot or something like setting the EQ or something.
Sure. Try these settings.
You can also find the .fac file attached but with a .txt extension (since the forum only allows certain file types); after you’ve downloaded it, change the filename and remove the last four signs (.txt) to make it a .fac file again (you can ignore the warning pop-up), then follow the instructions on importing and exporting presets linked below to add the preset.
If you encounter any clipping (distortion due to excessive loudness), turn the previously mentioned sliders (Clarity/Dynamic Boost/EQ) down a bit.
PUBG.fac.txt (958 Bytes)
thx you very much it’s work great. have a great weekend
Glad to hear that. :+1:
thanks a lot…
ive tried to use this but the file doesnt change for me and now it looks like theres more sliders on the right on my version
If FxSound still won’t open after checking Device Manager, try these steps:
  1. Uninstall FxSound completely.
  2. Restart your PC.
  3. Reinstall the latest version from the official site.
  4. Set your playback device as default before launching FxSound.
Thank you very much for sharing this. I have a question though: footsteps are relatively lower frequency compared to gunshots, right? Why would you need to boost the high frequencies?
I use FxSound with the WeeSound presets, and it’s been helpful for me. Here’s the preset I generated on WeeSound for my Inzone buds headphones—just note that it might vary slightly for each pair, so you can use it as a reference. For other headphone models, you’ll need to generate your own preset. For the guide, check it out here https://weesound.com/en/help
Hello, I have different Hz donuts below that I cannot adjust to, e.g., 75 Hz, which show in the picture max I got is 65
Hz
The frequency range issue is fixed in the latest beta version 1.2.11.0. You can try that.
Or you can set the number of bands to 31 from settings to get more frequency bands to control.
