Get sound boost but can't see FxSound window or see Equaliser to adjust. Help!
I have downooaded and installed seemingly O.K. and I have the icon on my desktop. The sound is bosted O.K. but when I click on the icon it doesn’t present a window on my screen so I can adjust the equaliser settings. Has anyone else had this issue?
Hi David,
You could try clicking the Windows button bottom left, search for FxSound simply by typing its name into the dialog box, and open it that way; or, you could look for the FxSound folder on your computer’s hard drive (C:), under Programs, and open it directly from its folder - and, when it opens, you could create a Taskbar shortcut for it (a.k.a. “pin” it to your Taskbar) by right-clicking the icon there, for easy future access?
Or do those methods also fail to work?
Let me know.
But please also note, that I will be hitting the proverbial hay very soon, in order to get the 8 hours of sleep all humans need.
Hi doolhoofd,
Thank you for your response.
I have solved the issue but in a different way – I rebooted my PC and it all burst into life, so happy now.
Regards
David
