Is this something you guys would like to see? It’d be a fairly big project for us, but definitely possible.
UPDATE: We’re now setting aside funds to go toward the development of FxSound for Mac! You can contribute here and select MacOS as the project you’d like to donate to if you’re interested in seeing FxSound for Mac come to life.
Yes please,I have bought the fx premium cause I was hoping that one day you will come to Mac so I wanted to support you.Is it possible that you add a function like autoeq to your mac version as a sound profile or just importing the files as profiles also would be nice…that the only thing that I miss about the program…but its my fav eq program cause its simple and sounds the best.
Hello James,
also, I am very much in favor of the Mac version of your great programs I recently came to this system with windows I should have purchased your paid version and have no regrets. But now I’m disillusioned with the transition to Mac and in a pinch I found at least the program boom two but it can’t compare to your great program also I strongly hope that one day you will create a version for MAC, until then I hopefully will have to run as a player a laptop with WIN:) but seriously. I will be happy to support you if there is a real plan to create it. Thank you for your wonderful work. Best regards Petr
P.S. I apologize for the use of the language facilitation aid (deepl transl.)
It would be great to see FXSound available natively on macOS. A lot of Mac users could benefit from its sound enhancement and equalizer features without having to rely on workarounds. Hopefully, the team considers it if there’s enough demand from the community.
