If I change either the Settings or EQ, then switch to the other, when I switch back my changes are gone. They will “stick” if I save but I do not want to create 100s of presets when I only need to change settings for the current media source. I’m using the paid 13.028 version and this is an extremely annoying problem. I spend several minutes optimizing my program material and it is lost as soon as I switch away from the screen I set. Of course, I could download the free version but the COLOR SCHEME is really a) hideous and b) extremely hard to read.
That’s a weird bug.
I’m not a tech guy so frankly I have no idea how to fix that, and support for the older versions has ceased…
If it’s the color scheme that’s bothering you, I recommend you post your wishes here:
Sorry we can’t do much bug fixing on older versions any longer, but I’ll count this as a vote in favor of a new color scheme.
