i’m facing the issue of getting no sound will running the FXsound but after disabling the FXsound i gets the sound. i did mostly every solution i can find on the internet and i came to a conclusion that FXsound doesn’t support 16 bits 48000hz & 16 bits 41000hz sound format . if anyone have any solution please reply. i really like the FXsounds interface if the FXsound doesn’t supports the 16 bits 48000hz & 16 bits 41000hz sound format please bring it to it
fxsound uses 24bit 48000hz but i dont think that the problem…
Hi @Aghori, Please check if the device volume, system sounds and individual application volume is low or muted in System > Sound > Volume mixer
No sound running any specific software (browser, media player, game) or not sound at all?
Yes i did check volume mixer, fxsound was at volume full including other program and i did set the output device as fxsound
and one more thing, before the problem of no sound occurs the volume mixer is acting on its on and changing the volume by it self of all the program except system sound all the other programs are changing there sound on there on i was not touching my laptop
no sound at all
please help T-T
