Audio works on speakers but stops after switching to headphones
The sound works correctly when I use my speakers. However, when I switch the audio output to headphones, the sound only works for about one second and then completely stops. After that, I cannot hear anything through the headphones until I restart the application or switch devices again.
I tested the headphones in other applications and they work normally, so the issue seems to be related to this app.
Could you please help me fix this problem or let me know if there is a known solution?
Thank you.
Can you check the volume level set for the headphones in system sound settings?
I have given volume setting for a device in Windows 11 10.0.26200.8457 as an example.
