Audio EQ and Output Device linking
I have created 4 EQs, each one that I use for my 4 output devices.
Example : Speaker 1 > EQ > Output audio device 1
Mackie Speaker 1 > EQ > Output audio device 2 (connected to Mackie speakers only)
Is ther a way to lock the left side permanently to the specific output?
That would be extremely useful as a speaker switching system with EQ (which is exactly how I use the software)
even is some devices disappear (ie bluetooth heaphones connect and disconnect)
Thank you for creating this software !
Ok I realize now this is already implemented but only when you select the output (right side) OUTPUT DEVICE PREFERENCE
WOOT !
  1. Can this also work when you select an item (EQ curve) from the left side ?
  2. Can there be an overall volume levelling attached to the preset alongside clarity , amnbience etc?
    It seems that the volume leveling is a global applied to everything.
    Can this also have a cut say -12db / +12db for leveling out different speakers?
The equalizer gains and the audio effects settings like Clarity, Ambience, Surround Sound, Dynamic Boost and Bass Boost are stored in the preset.
But, Master Gain, Volume Leveling, Filter Q and Balance are saved as application settings and common for all presets.
Yes I understand that! My suggestion is to add another leveler that is a non global!
