@bvijay I know I’ve seen this before… but could you remind me of what this error message is indicating?
Hi James,
This exception happens when the code tries to access a wrong memory address.
I am not able to replicate the crash and still trying to identify the root cause of this crash.
the application already works properly, thank you for your time.
@bvijay the application updated and it’s giving the same error again…
Ensure ALL your audio devices are enabled through Control Panel. Probably one of your main devices is disabled for some reason. Just ensure all your audio devices are enabled and it should work again. THEN choose which audio device you want it to work with.
The issue is fixed and I have released a new beta v1.1.31.0
https://github.com/fxsound2/fxsound-app/releases/download/beta/fxsound_setup.exe
