Unhandled exception notification
FxSound is not working in Windows 11 and gives “exception code: 0xC0000005”. Can you help please?
Hi @guc68,
Have you installed the latest version 1.1.31.0 from Download FxSound - Boost Your Sound On Windows?
Can you try rebooting and running FxSound.
I solved the problem. In the sound settings, it gives an error because the brave browser is not selected. Thank you
