Unhandled exception error message
Still getting the same error as of 02/03/25 when updating
is fixed after reboot the issue is fixed
ver 1.30
was having this error today after updating the app. solved it by disabling and enabling the app driver via device manager (Windows 11 Home Single Language, 24H2)
Excellent! This fixed it, with no reboot required.
thanks much.
To fix this error, first you need to uninstall the application on the control panel. Then you need to go to the folder where fxsound is saved and delete their files. Finally, after completing, reset your device and reinstall it.
Unplug headphones or speakers, that worked for me
