Hello everyone, everything good? I have this preset that I use on my smartphone (App is called ‘equalizer’) and I would like to reproduce this same configuration for fxsound, could you help me?
Good evening Felipe,
Sure, no problem.
I’ve made three versions of the Preset you requested: a first one with a slight boost, a second one with a moderate boost, and a third one with a heavy boost.
The forum only allows certain file types to be uploaded, so you’ll need to remove the .txt extension during or after saving the .zip archive, unpack it, then follow the instructions on importing Presets linked below.
Feliz.zip.txt (1.5 KB)
Thank you very much doolhoodfd, these presets are getting a lot more bass now hehe.
I’ll test some more configurations based on what you did, but thinking logically, I think the audio difference is actually physical, perhaps the smartphone’s audio processing chip is very different, but it’s already much closer.
Thanks so much for sharing these presets XD
Happy to help.
P.S.: FYI,
