It's not opening, it's giving an error
Are you seeing the same error?
Can you share the %SystemRoot%\inf\SetupAPI.dev.log again from the Windows 10 driver installation.
I sent
I followed the steps, but it didn’t work.
I looked at the log file you sent. The removal step may not have completely removed the old driver. Can you try using tools like lostindark/DriverStoreExplorer: Driver Store Explorer to completely the remove the driver and then reinstall the win10 driver?
The problem is solved; thank you for your help.
Will there be any problems with the new strengthening? Will you make the necessary arrangements?
Will there be any issues with the new update? Will you make the necessary adjustments?
i too have the same error
Hi @kl5e6l3m1p5
I am trying to understand how Windows 7 driver could have been installed on Windows 10. So, I have not made any fixes for this issue.
If you have any additional information that you can share about your setup, it will be helpful to understand and fix this issue.
@shanmukha Can you try the steps that @kl5e6l3m1p5 has followed to fix this error?
