On my laptop i have 3 ways i listen to things, External speaker, Headset and the built in speakers. Is there a way to have FX sound only on the built in speakers?
Good evening Owen,
The easiest solution would seem to be to just use the main purple power button whenever you need your audio processed.
Alternatively, you could also make a “flat”/zero processing preset for audio that does not need to be boosted, and switch presets when changing devices.
Let me know if this helps.
