Main gain, and so on
Hello.
What happeend with the Volume section via the settings? I got an update today, and those main gain, and other volume settings are simply gone. i deinstalled and installed FxSound again, but it stay the same. That was a great feature, and all of it is gone, since the update from today.
It would be nice not to delete those volume options via the settings. Those gave me also a way to put a preset for each device i use to listen: laptop, headphones, krk5 speakers etc.
The settings are moved to the main window.
Use the flip button on the audio effects controls. You will see the additional controls for equalizer bands, master gain etc.,
