Thanks for the great software! I’m still learning how to use it for best results. But one thing I would like to change is the color, from its original red to green, which happens to be my favorite and looks great with black. Is there a way to make that change? TIA.
]Good evening Paulo,
Short answer: no.
Currently there is no way to change the appearance of the interface in FxSound itself.
But I will keep your suggestion in mind for future purposes.
I have version 1.19 now. is this a beta version?
No, just an update.
changelog ?
Should be updated soon at
https://www.fxsound.com/changelog,
but in the meanwhile:
Just adding a post from user @JMBWITHCATS with a similar desire to change colors,
Adding another similar request by user @Ananda96 posted about an hour ago:
@Paultx
@Ananda96
@lmurray3
@JMBWITHCATS
A quick link to the feature request regarding the UI’s appearance on GitHub:
Adding a similar request regarding the color scheme of the UI, posted earlier today by @Ayjjala:
I’d love to see more UI color options as well, even gradients if possible.
Any update on being able to to change the UI color or adding skins. I had the originial fxsound app and at least the blue color was better than the current black.
We will try to add the option to change UI colors in the near future!
i would like to change colors speciali green colors can you please to that
