Hello, FxSound produces no sound when processing is enabled and displays “unable to play processed audio through the selected output device.”
My system:
HP All-in-One 22-dd0123w, product 1K0K4AA.
Windows 11 Pro, build 26300.
FxSound application: 1.2.16.0.
FxSound driver: 14.1.0.0.
Realtek audio driver: 6.0.9264.1, installed from HP.
Windows sends audio to FxSound: its playback meter moves, but the Realtek meter does not. Realtek plays normally when selected directly. The Windows “Test” tones on Realtek also work while FxSound is enabled.
Already tried without success:
Reinstalling FxSound and restarting Windows.
Installing the HP Realtek driver and restarting.
Disabling exclusive mode on both devices and Realtek audio enhancements.
Setting both devices to 24-bit, 48000 Hz.
Checking volume and mute settings.
Renaming the FxSound configuration folder to let the application recreate it.
I attached the diagnostic reports and error screenshot. This looks similar to "Unable to play processed audio" on every output since the Sept 2026 Windows update, even though every WASAPI step succeeds · Issue #631 · fxsound2/fxsound-app · GitHub , but I cannot confirm the same cause.
Which application logs or diagnostic build would identify the actual output initialization error?
