Does not work in latest Win10 LTSC
Works fine on my downstairs computer which has a slightly older LTSC. The upstairs laptop which has the very latest version, not so much. The older dfx one does work upstairs, but nags for a password.
Of course, the laptop upstairs is a little older, AMD A6 with 8g ram and 500gb 870 ssd, so it could be the hardware too.
Any suggestions…??
Hi Rick,
The older programs are still available as free downloads on fxsound.com.
Just scroll to the bottom, look under “Products.”
These will probably be slightly different versions than the ones you have, and they will not ask you for a product key, since they are now free for all.
As for possibly using the new program on your upstairs laptop, can you first please explain what kind of errors you are getting?
I doubt it’s the hardware’s fault (my laptop dates back to 2011 and the new program works just fine on it).
@TiM: Any suggestions?
Getting the “oops there’s an issue” error.
I’ll look for a version that doesn’t need a serial, should be good enough, I’m not picky… ::
Thanks
Okay, informative; there’s a thread for that error:
Vijay has suggested some troubleshooting there:
Please briefly report your findings here after attempting to solve the problem, thanks.
Happy to help.
doolhoofd
Alas, FXsound does not appear in the device manager at all.
I will say the new one does sound fantastic blasting my moldy oldies down in the basement… ::
Sometimes, devices in the Windows Device Mangager are hidden. You can use “View => Show hidden devices” from the top menu to make them visible.
This especially occurs when the device in question is not connected to the system but the driver is still installed.
Cool, I’ll check that out. Thanks.
Never gonna give you up, never gonna let you down, Rick! :musical_note:
Another user with the same problem got it to work simply by uninstalling and re-installing a couple of times, so I highly recommend trying that.
Yea, did that at least an dozen times.
Got an older version to work, just gonna leave it at that for the time being. Thanks everyone for their help.
Rock on…!!
